It was like watching Monster Jam Free StyleIt looked like a good ramp!
-Go on photobucket and get a Direct Link (or right click the picture, save image address)Not workin.....i can't figure it out.
I have the smaller bushing the XL uses as well. Should I use that or fuel tubing like you suggested?Only wrong thing I see is you are using that heavy brass bushing at the end of the bell, that alone will wear the bearings quickly, I was told by Mickey a long time ago to substitute a piece of fuel tube in place of it, so I did as he said and it actually works very well.....
More pics to come soon. I have the engine installed right now and will swap out the slightly used vented bell with a brand new hardened HPI bell. There's about a 3mm gap between the face of RRP Gen3 Spur and face of the Vented Clutch bell.InTheZone, you have a sick setup going on there, but I do see an issue with it, at least as far as I can tell. I am planning on running the same engine with a similar clutch. However, with that vented bell and the RR metal spur, I am pretty sure they will rub when you go to install the engine. (because the vented bell has an extra few mm on the front, you can see what I mean in your second pic). Because of this I was planning on having to run the HPI metal spur gear since it is much thinner than the stock plastic or RR spur. Could be wrong but let me know.
More pics to come soon. I have the engine installed right now and will swap out the slightly used vented bell with a brand new HPI bell. There's about a 3mm gap between the face of RRP Gen3 Spur and face of the Vented Clutch bell.
Yep... been there. 1/2 tank of fuel after installing the RC Solutions tool steel spur into my big block t-maxx 15 years ago. Just used whatever 1M bell I had at the time... made for a pretty spark show. lol!One thing to keep in mind when using a different clutch bell is to make sure it is hardened so that spur doesn't eat the bell gear...
Looks nice, let me know how the suspension (shocks and arms) holds up.I added the FLM tierods and finished buttoning up the electronics. Just using all the oe stuff for now as is still works great.
View attachment 6557View attachment 6558View attachment 6560
I’ll definitely do that once it’s broken in and I can get some bashing done. I got a question tho regarding your nitro build. What Size spur and bell are you using. Mine currently has a 16t bell and 52T spur and absolutely zero chance of fitting in this chassisLooks nice, let me know how the suspension (shocks and arms) holds up.
Before my rebuild I was running an Integy Motor Mount, original style RRP 52T steel spur and either a 15 or 17T vented clutch bell (can't remember because I have both in my parts tray)I’ll definitely do that once it’s broken in and I can get some bashing done. I got a question tho regarding your nitro build. What Size spur and bell are you using. Mine currently has a 16t bell and 52T spur and absolutely zero chance of fitting in this chassis
How do those carbon fiber brakes compare to the red fiberglass? I wanted to stock up on some spare brakes and saw a bunch of these, but was worried the discs would glaze and the braking would then suffer.Installed a pair of full force RC carbon fiber brake disks:
Forgot how much of a pain it was to install brakes on the savage without removing the trans case.
Also changed the CB from 16T to 15T to help with the mass of the trencher 3.8's:
Had to raise the engine a bit so the CB didn't drag on the brake disks making it so I couldn't get good mesh:
Also made an ugly little mount/support for the t-bone rear bumper/skid to connect it to the rear skid "softly" so as to hopefully not break the screws off in the skid plate again that hold the stock bumper down. I also lost the plastic bit that keeps the t-bone wheelie bar from going in too far.
I ran a similar single disk on my aftershock back in the day when I had it. It came with dual steel disks and steel pads, which had a horrible binding issue once the disks wore a bit and would flop around on the trans cup. Then I got a CF disk (I think the from full force rc as well) and ran with that. With the single disk, it didn't bite as hard, but it worked fine even over time as I ran it. With the savage, I figured I'd try and fit 2 of them, then I get a bit more bite without taxing the servo so much.How do those carbon fiber brakes compare to the red fiberglass? I wanted to stock up on some spare brakes and saw a bunch of these, but was worried the discs would glaze and the braking would then suffer.
