try 2 turns on the second gear and 4 1/2 to five turns on the third..
When you remove that set screw there is really 2 of them 1 right underneath the one you removed.. once you remove both set screws those gears will come off the shaft, then you will be able to adjust 2nd
That little spring and ball is what adjusts your shift, points.. they go on the clutches.. Ok those two set screws your remove there is another one right right beside it(it kinda goes in at a angle that's where that spring and ball go before you put the set screw over it ...
So sorry If I really confused you but its hard for me to explain , but iam going thought the same thing you are right now... Please guys correct me if iam wrong , and our.. put my words in in something that ain't so screwed up
