just costs for parts, I would fix it all free..... I cant stand all this trouble you are having with no relief in sight for you....
If it's not put together right, then there won't be tension on the shoe holding it in. That shouldn't stop the cb dead, but it will make it very difficult to start as the dragging shoes will kill the engine. Could also be the springs are sprung/stretched out.
That said, if the CB only spins freely when you loosen the bolt holding the CB on, then your issue is a shimming issue. With proper shimming, the screw should be tight and the bell should spin freely, even with a hair of play so it doesn't bind when things heat up and expand. You cannot run with a loose CB bolt or it WILL fall out while running which will torch your spur, possibly the shoes and lose a bearing.
