Skyline1473
Thanks for trying to help.Ah, I'm in Rothesay on the Isle of Bute
Is that better. Its powered on the rig and the brakes are applied so wont run freely when pushed.
How do i do that pleaseThat is not centered. The servo horn assembly should be perpendicular to the TVPs when neutral. Look at my instructions in my previous post.
Is that the 4 screws on the bottomwhen it rolls backwards it is turning the spur and bell so if your is not rolling well backwards then it is the spur and bell mesh that is causing this issue.
you have to loosen the 4 mounting bolts and slide the engine away from the bell just a bit.... I went over this with you yesterday so now you must do some work and adjusting for yourself.....
4 bolts beneath the engine yes but it looks it will only move sideways.when it rolls backwards it is turning the spur and bell so if your is not rolling well backwards then it is the spur and bell mesh that is causing this issue.
No i don't have the skill to strip engine mate. So you're saying because something is bent its not rolling back and the spur bell mesh wont rotate freelyIt is because the is only going to slide side to side, it will NOT move back and forth, I told you this also earlier... as for that misalignment issue I am sure something is bent, it is past time to take it all apart and find what is broken or bent......
do you have the mechanical skill required to do this only you can answer. these are NOT toys, they are a full on model of a 1/1 truck and everything has got to be in alignment and not broken to make it work as intended....
Ive managed to get the carb setting right and the servo and now it will free roll forward but not backward. I'm gonna try and get the spur and clutch bell mesh adjusted by moving the engine away from the c/b and see if that helps if not gonna take engine out. The spur and c/b is impossibly to move by finger so maybe its the mesh thats not right anyway will keep you guys posted. Unfortunately i don't have any rc stores near me.Skyline,
I have just read through this whole thread. Although Jam and others have been extremely helpful, not having the truck sitting in front of them makes this process extremely difficult. Unfortunately, this purchase is most likely going to taint what is a very fun and enjoyable hobby.
In my opinion, you will need to find someone local to you to help you. Most R/C hobbiest will be more than happy to assist, Local Hobby Stores will also help at a price.
If you cannot return it, you may as well take it apart. If you remove the engine, you will be able to determine 1, if the truck will now roll, and 2, if the clutchbell will spin freely.
In regards to your throttle servo, if everything is charged up and turned on, the servo should respond to the trigger, always.
Best of luck.
HiThe spur should definitely spin in at least one direction easily. The other direction causes the truck to move forward. If you hold the clutch bell stationary, you should be able to rock the spur back and forth just a hair. You want a little play, but not a lot. The spur should spin very freely.
Took a quick video of mine:
My mesh may be a bit on the loose side. At the beginning, I have a screwdriver holding the clutchbell stationary so you can hear the "tick" of play between the bell and spur. Then I spin it in the free-spin direction (clockwise from the rear) then I spin in the direction that rotates the tires (counter clockwise from the rear). This gives you an idea of what it should do.
I got it so its my spur gear which has slight movement like in the video but will not rotate freely.Skyline,
I think you are naming things incorrectly. The large gear on top is the spur gear, this is the one you tighten the nut to compress the spring.(the manual Says to then back off, most here say not to)
The small gear meshed to the spur is the pinion gear(drive gear), it is attached to the clutchbell, which is on the front of the engine. The clutchbell rides on bearings on the front of the crankshaft, and should spin freely in either direction when not in contact with the spur gear. All of this while the engine is not running of course.
If you send me the truck I will fix it all and get it running and when done will ship it back to you, you will need to pay shipping both ways......
I have said it before and will say it one final time, tear it all down to components and inspect EVERYTHING over well.....
