Melting spurs and stripping clutch bells
M4tty69
hi all,
Sorry if this has already been covered in another thread but I had a little search and couldn’t find an answer..
I have two problems here. Firstly I shall say that my savage x 4.6 is only used for bashing and it takes quite a beating so I expect to break things but this is getting a bit silly now.
When running stock HPI plastic spur gear and heavy duty clutch bell after a while I end up with a spur gear like this! All shredded and almost looks melted?!
I then switched to a hpi steel spur gear with the same heavy duty clutch bell and it just strips the clutch bells! At £15 a pop I don’t really want to be using a clutch Bell every time I go out, sometimes it’s only lasting 30mins before it’s stripped again!
I don’t think it’s down to the mesh being wrong as I always spend the time to get that perfect mesh.
I have thought maybe the engine is moving when landing hard and rolling ect but the spur and clutch bell seem to strip sometimes when I haven’t even jumped it yet?!
Over to you guys!
Am I using the correct gears? Is there anything that better? Is there a way to stabilise the engine for bashing?
Thanks in advance!
The plastic one looks like your mesh was way too loose. What brand "heavy duty" clutch bell were you using with the steel spur?
I use HPI's HD bells with the HPI steel spur and it holds up fine for a very long time. I used to only buy OFNA hardened bells, they would last forever, but you can't find them much anymore.
+1 that plastic spur was set way too loose. All you need is just the slightest amount of play between the clutch and spur. All I run is stock plastic spurs and bells with no problems.
