Bankrupter
Well its time I get to making a thread about the stuff stacking up over here..
I'll get the pics up for now, and think about how I will word up the thread later. We all love pics right!!!
You all have seen it b4, But here we go again:
The chassis - Full PRC XL carbon with low pro shocks towers:
RSC modded FLM bulkheads: How to thread --->Here<---
Front end servo location:
The given mount holes on left.
Where I moved it to.
First bolt up "mock".
Final design had to recess screw for the TX box.
A few shots of the -=Temporary=- linkage.
I cut a old turn buckle up and made this up with scraps.
Again that turn buckle I will replace.. This is to show how I spaced it off the arm to get it all straight and level pulls
The transmission:
HD with optional gear ratio.
This pic is a old case,now new as seen later all shiny..
Now that you got a peak of them...
The mechanical brake's:
Drilled in FLM servo mounts
Shortened brake rod and servo: (waiting on arm in mail)
OK found this old bone in a draw tonight and gave it a face lift ..
Dremiled up ..
Ritt dye to the rescue of the ugliest colors...
Much better!!!
from page 2 ...
Almost done now....
Got hardware in tonight. Screws are fine but the blue ano on the washers flat up SUCKS! So now another thing I have to reorder... Something is to be said for a good LHS where you can hold the stuff and not net pics that when you open the box make you sick ...
I put it together for this weekends bash anyways. Not gonna butt ugly blue keep me from running it ..
Screw order.. I got some spares.
As always nothing ever bolts up. So the ole grinder got a lil work out ..
I left the melted duct tape on the washers I wrapped my vice with for grinding... that's how much I hate this blue..
Grind, grind, grind some more..
SO UGLY
DID I SAY UGLY YET ??
OK test time ... Anything has to be better then this blue ...
lil primer..
Then a lil black paint..
OK black works, time to order..
Finished the mount for the temporary switch. Hit it with some hammered look paint to blend in.
Put the brake linkage in Also batt boxes
Modded a hellfire wing stay to work with towers
Thats done ...
Unfinished wiring:
What ever this was on top. ( Truck is from scratch, all sourced parts... I have no clue what this is on a flux ) I cut it into the bottom shape as a wire stay...
Put it here.
Again not finished but mocked up wires in stay.
OK lil work here today...
Cut motor wires down and re-soldered
Much cleaner!!
Top view of wires. Also shows the start of the switch bracket (unfinished). That will be temp till the switch goes, then ~CLIP~ No more switch...
Extended Motor Plate for rear ESC:
RX box:
The power system:
4-5-and 6S matched set up
2-2S, 2-3S Hyperion G3 35C 5000 mah packs and twin 720 I net 3's
Almost done... Hope to have a package with the odds N ends today with all else (&@^% A-Main hobby is slow...) Final pics to come ..
The transmission:
Dremiled up ..
Much better!!!
from page 2 ...
Almost done now....
SO UGLY
lil primer..
Thats done ...
Unfinished wiring:
Put it here.
Much cleaner!!
RX box:
The power system:
