joe out of curiosity how much does a complete kit set you back?
Well to see the progress of that truck. It's sick!
I'm thinking 86056 is for the dog bone between the back diff and the transmission
Ok so what is this for? I had bought the two because i did not want to drive 4 hours total and get the wrong one.
HPI part # 86057 8x78mm is the right dogbone for the front. HPI part # 86056 8x84mm is the rear dogbone for stock length TVPs. So, the one you need to use is 86057 8x78mm.
Are the measurements of the hellfire shaft and stock BB shaft exactly 70 and 90mm??? i only ask as i have someone who may be making some actual TI Shock shafts, not just TI Coated...
Just , WOW! I hope to do an 1/8th of that cool stuff to either of my trucks. Thanks Joe.
]-[0pa]0ng;190716 said:On your shock towers why are the nuts facing outwards? Wouldn't it look cleaner if the where facing inwards? with the screw head facing outwards? JMO.
]-[0pa]0ng;190716 said:Nice work bud. Love the Cen tank look. Question - why do are using a philip head screw when you have cap hex heads on the frame? Need another hex head screw. On your shock towers why are the nuts facing outwards? Wouldn't it look cleaner if the where facing inwards? with the screw head facing outwards? JMO.
Great info. I don't think I've seen that tank get used yet. You defently got the sucker as low as you could LoL
Thanks for the pics rockout
