So today see as the weather has been crap & that I'm a sad old git & this issue has been bugging me since I put these truck together, I decided to change the TVPs over on my 2 Truckzillas. The reason for doing this was that although both trucks are Hotbodies Truckzilas they have different TVPs. I think one is a Truckzilla Sport. the silver ones (this being the sport) are higher at the rear and wouldn't allow for the rear exit manifold to fit correctly, the manifold had to face up making the pipe sit to high. These trucks originally had a 4.6 cu in(7.5cc) mill which had side exit exhausts. The Gold TVPs are lower at the rear but was running these with a rear twin pipe. Also had to notch out the chassis on the silver set to allow the mill to fit nice, think this is because the spur gear is a 52T which pushes the mount all the way over to the right.
Anyway both trucks are now back together and must say now happy with both of them.
Truckzilla 1:-Before see the manifold was sitting on the chassis.View attachment 9985
After the manifold sits lower and does not sit on the chassis
Truckzilla 2:- before
Truckzilla 2:-After
Have just worked out why the TVPs on the Truckzillas are different. The silver ones come with the complete truckzilla kit which included the .46cu in(7.5cc) mill where as the gold ones are from the truckzilla sport which kept the original savage 25 rear exit exhaust motor. The sport TVPs are only 2.5mm thick as opposed to the silver ones being 3mm.
Looking good as ever mate, wasn’t aware of gold version! 👍🏻
Cheer bud, the gold chassis is painted mate, it's cause of the different styles I switched them over. The gold ones are the sport type designed to be used with a rear exit exhaust port mill where as the silver ones are meant to be used with a side exit exhaust ported mill originally designed for the Hotbodies .46 mill. The gold set allow the exhaust manifold on the K4.6 I'm running to sit correct, on the silver ones it don't matter as the K5.9 I'm running on that truck has the twin rear pipe.
I haven't used my Savage X in around 12-13 years, but here are parts I have ordered and will be installing once they arrive:
-HPI Super HD Dogbones
-HPI Super HD Diff Shaft
-HPI Extended Axles
-HPI Machined 29t Diffs
-HPI Machined 9t Bevel Gears
-HPI Fiberglass brakes (currently have metal)
-Robinson Racing 47t Gen3 Steel Spur
-Robinson Racing 17t Hardened Clutch Bell
-HPI Ceramic Slipper Pads
-HPI Sway Bar Set (found this at my only local hobby store after going through every parts bin they had)
I'm still waiting for my new Futaba radio to come in, but I'll be re-using my old Hitec servos until those go bad. Also waiting for LRP to restock their .32 Spec 4 with pull start. The only part I cannot find is the high speed 3rd gear set PN 77065, even tried looking for Savage XL 5.9 transmissions that someone might be parting out but no luck. And I have other small things coming in like o-rings and shims for the diffs. I still need to remove my broken S25 motor to see if I ever upgraded to a 3 shoe flywheel, if not I'll be ordering one of those as well. Pictures will come soon with a before and after installation. Can't wait!
https://www.fastlanemachine.net/proddetail.php?prod=FLM44300
Ran all three Savages, a 21, 25 and XL. 21 & 25 run .28 motors and the xl runs a .36. Ran like dreams as the warm weather comes. Only problem I have is the sleep needs to have the second gear shift adjusted, otherwise - fantastic !
Replaced stock rear hub carrier assembly with single piece aluminium conversion and swapped the rear upper arms for adjustable ones at the same time.
Just thought I’d have a spring clean of my man cave I haven’t been able to do anything rc over the winter because of crazy work schedule but hopefully taking a step back now so better days ahead!
Took my pride of my fleet of the shelf and omg the drive shafts are all corroded which was easily rectified but what shocked me (no pun intended) one of the shocks are bent😳 it’s never been anywhere nor turned a wheel in anger is my queen of the shelf obviously bent from the factory!
Got the place to have my own personal track now, so got another savage last Friday off marketplace. Gotta have at least one in the fleet says I. Pretty lightly used x4.6 all stock except the wheels and tires. Guy put a slipper eliminator and steel spur on it but left the stock clutchbell, DOH! So I'm on the hunt for both, where are we able to get parts these days? Seems pretty hard to find stuff.
I ordered a mid tank kit with lcg xl tvp's from FLM and they shipped today. Guess there's no more OFNA for linkage kits anymore huh? What are you all using? Also open to suggestions for a tank.
Was told he put the 3 speed in it so not sure what gears go with. Also got the baja hex adapter kit as I have a whole mess of 5T tires. I have a 5t, 5b, and the losi dbxl so lots of options in stock.
Fastraxx do a decant linkage kit here in the UK couple o pen springs n a mountan bike spoke 👍
there are stl files for the linkage sliders, collets should be avalible in any hobbyshop and in my experience best linkage rod alternative is a mtb spoke
