Crash's Axial .32 Spec 1
It never does it on pavement, just in the grass
I giggled too, 2 nd gear wheelie. nice
I love mee savy
I WILL SHOW YOU GRASSHOPPER​
O'YA these stock shoes are toast.
They are barely going to make one gallon
I will give it some NOVA'S now http://www.novarcproducts.com/clutchshoes.html
They did not make it through a gallon.
I took the cb off to inspect them again and they were worn down to the springs.
I switched them out for some used shoes I had sitting around and they worked for a tank and now they are dragging so, I'm going to the lhs today for shoes
The engine seems to be broke in now. one gallon of fuel is gone through it
alright, put a set of new stock hpi shoes on
forgot I had them from my street savy
also switched up the gear combo
before: 47/18 2.61
now: 52/17 3.05
Its a little low for this mill but, its fuuuunnnnnnnnnnnnn!!!!!!!!!!
In conclusion of my first gallon:
I would say this mill has more torque than the .28 rr spec1 but has less topend, IMO
I increased the slot width in the engine plate
the engine is up against tvp now as far as it will go
How did you get 52/17 to fit .. I have a hard time w/ 52/16 ..
I have been running an 18/52 for the last 8 months. Slotted engine plate, and slight modification of the engine mount... but it fits. When I went to Savvvy 25 TVP's I had to grind a relief for the flywheel, but it fit okay in the X TVP's.
52/18 would be better, 52/17 hits pretty hard off the line and runs out of rpm's on the top
thanks metal,
Its never got over 188 degrees, when it warms up it little more snappy of the line
I need a camera man for that shot Jermey.
as you could see that video was shot in the small yard behind my shop.
I never saw second gear.
One thing for sure, I don't bs,. across the field behind my house a saw second gear wheelies from this mill with a 49/17 gear and stock hpi shoes.
now I'm 52/17 so the power is alot lower in the powerband, still lots of fun
I know you don't bs bud ...
Hire the kid next door , or give the bumb down the street a bottle of cheap vodka..
heay crash got a 32 spec with about a gallon thru it runin 49 17 gears got the mill from a spoiled nephew that got bord with the hobby never hit over 250 still strong but not to what yours does any idas on gittin the ole girl gooin with out a rebuild
just tuneing, I found that it needs alot of fuel on the highspeed needle
but, needed a 3/4 turn in on lowspeed needle
also, be sure to use a cold plug
and 30% nitro
gear down a little for hard hitting wheelies
