Chris Down
Thanks mate that is helpful. 🙂Small flat blade screw driver to remove the clutch shoes. Lightly pry them off. I put a rag around the flywheel and use channel locks to hold the flywheel. There are videos on youtube also.
Ooh hadn’t thought of that. I will thanks.Be very careful putting that engine mount in a vice. They crack easily
Oh Kay trying to reassemble the clutch. Bloody hell the springs are fiddly to fit!! Not getting on well here. Any tips?
Omg I am so gonna get one of those. Thanks. I’ve got three big block nitro trucks so it will be used. 🙂I usually just use a flat head screw driver. If you find you want something a little more designed for the task, there are many clutch tools out there. I have used THIS one, it does fairly well.
Think I need to watch a video to see how that one works.I usually just use a flat head screw driver. If you find you want something a little more designed for the task, there are many clutch tools out there. I have used THIS one, it does fairly well.
