Rota start
Stonecold2k1
Hi my husband has the savage K 5.9 and he has changed it from a rota start to a pullstart but it's no turning the engine over at all. Please can anyone advise him on what he can do. TIA
He most likely installed the one way bearing on the back of the engine backwards. Like the name suggests it only spins the shaft one way, if you put it in backwards it will just spin. The part of the one way bearing with the silver metal lip on it goes towards the front of the truck
He didn't buy a new One way bearing all he did was take the rota start off and put the pull on
Did he take the back plate off, because there is a small spring loaded pin in the crank that the starter catches. It pops out quite easily when taken apart.
