Savage 25 motor
Zep71
Ray City GA
Hi guys i purchased a savage 25, and was told the motor was rebuilt then put on a self for 8 years. this guy told me parts are still available i am finding this not to be the case the connecting rod in this motor is no good the clutch is also no good here is a video of the connecting rod
i am trying to figure out a good replacement motor, so here i am. this had a .26 on it.can't seem to find a new one or even parts. any idea what i should do with it?
Thanks
Thats terrible I'm sorry that someone took advantage of you like that. Carma will get him i see why it set on the shelf for 8 years. Parts for the savage 25 are had to come by but parts on the savage x are interchangeable with it. There is a couple different parts but nothing that cant be changed. What engine you looking for?
I am looking for a direct replacement motor that would be equal in power
don't really have a budget.its more of where to draw the line of is it worth it.
Can one of you explain the difference between the .26 and the 4.6?
The .25 is really a 4.1 - the 4.6 is a .28 - i.e. bigger...
RTR Savage 21 RTR Savage 25
Engine 21BB Nitro Star S-25
Starting System Manual Pullstart Roto Start System
Spur Gear 52T 49T
Clutch Bell 14T 15T or 18T
Clutch Type Two Shoe Three Shoe
Shock Springs Red Medium Black Firm
Fuel Tank with primer, front pick-up without primer, rear pick-up
Body Black - Silver - Purple Red - Black - Silver -Gray
Size .21 .25
Horsepower @ RPM 2.3hp @ 30,000 2.5 @ 29,000
Maximum RPM 38,000
Heatsink Head cast metal Machined Aluminum
Case silver Black Heatsink Coating
Carburetor metal Composite
Carb Adjustments high, mid, low simplified to High and Low
Connecting Rod single bushing Dual Bushing
Construction ABC ABC
https://www.hpiracing.com/en/part/1495
Thanks
Need to junk that one,there are cheap.28 nitro motors out there amazon has one for59 dollars
