Savage 25 motor
Discussion in 'HPI Savage Octane' started by Zep71, Aug 12, 2017.
  1. Zep71
    Zep71 Member
    8
    0
    Aug 12, 2017
    Ray City GA
    Hi guys i purchased a savage 25, and was told the motor was rebuilt then put on a self for 8 years. this guy told me parts are still available i am finding this not to be the case the connecting rod in this motor is no good the clutch is also no good here is a video of the connecting rod
    i am trying to figure out a good replacement motor, so here i am. this had a .26 on it.can't seem to find a new one or even parts. any idea what i should do with it?
    Thanks
  2. NightFlier X4.6
    NightFlier X4.6 Well-Known Member
    683
    66
    Mar 21, 2015
    Ohio
    Thats terrible I'm sorry that someone took advantage of you like that. Carma will get him i see why it set on the shelf for 8 years. Parts for the savage 25 are had to come by but parts on the savage x are interchangeable with it. There is a couple different parts but nothing that cant be changed. What engine you looking for?
  3. Zep71
    Zep71 Member
    8
    0
    Aug 12, 2017
    Ray City GA
    I am looking for a direct replacement motor that would be equal in power
  4. NightFlier X4.6
    683
    66
    Mar 21, 2015
    Ohio
  5. Zep71
    Zep71 Member
    8
    0
    Aug 12, 2017
    Ray City GA
    don't really have a budget.its more of where to draw the line of is it worth it.
  6. NightFlier X4.6
    683
    66
    Mar 21, 2015
    Ohio
  7. Zep71
    Zep71 Member
    8
    0
    Aug 12, 2017
    Ray City GA
    Thank you is the 4.6 to big? i have no clue about engine size
  8. coreyh29645
    coreyh29645 Member
    43
    9
    Jun 17, 2017
    stafford springs ct
    no such thing as too big!
    • Like Like x 1
  9. NightFlier X4.6
    683
    66
    Mar 21, 2015
    Ohio
    No its a pretty good power plant as well.
    • Like Like x 1
  10. Zep71
    Zep71 Member
    8
    0
    Aug 12, 2017
    Ray City GA
    Can one of you explain the difference between the .26 and the 4.6?
  11. NightFlier X4.6
    683
    66
    Mar 21, 2015
    Ohio
    The .25 is really a 4.1 - the 4.6 is a .28 - i.e. bigger...
    RTR Savage 21 RTR Savage 25
    Engine 21BB Nitro Star S-25
    Starting System Manual Pullstart Roto Start System
    Spur Gear 52T 49T
    Clutch Bell 14T 15T or 18T
    Clutch Type Two Shoe Three Shoe
    Shock Springs Red Medium Black Firm
    Fuel Tank with primer, front pick-up without primer, rear pick-up
    Body Black - Silver - Purple Red - Black - Silver -Gray
    Size .21 .25
    Horsepower @ RPM 2.3hp @ 30,000 2.5 @ 29,000
    Maximum RPM 38,000
    Heatsink Head cast metal Machined Aluminum
    Case silver Black Heatsink Coating
    Carburetor metal Composite
    Carb Adjustments high, mid, low simplified to High and Low
    Connecting Rod single bushing Dual Bushing
    Construction ABC ABC
    https://www.hpiracing.com/en/part/1495
  12. Zep71
    Zep71 Member
    8
    0
    Aug 12, 2017
    Ray City GA
  13. Tgum
    Tgum Member
    13
    0
    Mar 3, 2017
    Need to junk that one,there are cheap.28 nitro motors out there amazon has one for59 dollars
Verification:
Draft saved Draft deleted
Share This Page
