wheelie
Oh Gee Jay
edmonton, alberta
ok this is my 1st r/c so my first tuning. i thinks its tuned good i see smoke runs good temp stays at about 230-250 depends on how hard i drive it but i cant do a WHEELIE lol but my truck is a savage 25 with a K4.6 big block and everything else is pretty much stock
52/14 you should be pulling stumps out, but thats not stock gearing. stock was 15 and 18 for the 25. either way if you have a decent tune you should be pulling wheelies on command with those setups.
according to the owner's manual if you have a Savage 25 & your gearing is stock, then you have a 49t spur (p. 32) and a 15t cb (p.46)
Check your slipper and make sure its tightened down. manual says to back off 1/8th or 14 of a turn, but I keep mine tight. Check you clutches and make sure they are not worn and the inside of the clutch bell to see if its glazed over. If the CB has a build up, it can be cleaned with fine sandpaper to scuff it up. You may want to lean the LSN a touch(not too much) to give you a little more punch onthe low end.
yeah i got new pads that go on the back of the spur gear and i thought they gears were stock but i bought it used so i know now. i will try it in the next couple days I'm still waiting for some breaks to come in the mail.
thanks for the help everyone i will post if i get it on 2 wheels
well i changed the slipper pad and put it tight and cleaned the clutch bell thing on the inside put a 3 speed now its on the roof all the time lol thanks for the advice guys
