what is the diff. in the rpm range
609savage
dirty jerzey
well i been looking at different engine to get and i noticed that they all have different rpm's should i get a high rpm like 39,000 or low like 21,000 what is better for my savy x with extended tvps and 1/2 offset wheels...i only bash ...not rock climbing type of driving
i found this motor is it good???
This is the Peak Racing Diablo .28 Engine with Pull Start.
Ideal for powering monster trucks such as the Associated Monster GT and the HPI Savage.
PEAK PERFORMANCE #6081
BRAND NEW in the package!!!
FEATURES: Same mounting dimensions as a .21 size engine.
ABC designed piston and sleeve.
High performance 8mm aluminum slide valve carburetor.
Knife-edge double bushing connecting rod.
Two piece replaceable button style turbo head.
Three intake, one exhaust race spec porting configuration.
Skirted double oil groove piston design.
Rear exhaust.
Black aluminum cylinder head with 12 cooling fins.
INCLUDES: One Peak Racing Diablo .28 engine with pull start, glow plug, sticker
sheet, rubber exhaust gasket, brass collet and instruction manual.
SPECS: Crankshaft: Standard SG
Horsepower: 2.85
RPM (max): 42,800
Bore: 18.8mm
Stroke: 16.5mm
Distance between mounting holes same side: 0.83" (21mm)
Distance between mounting holes opposite side: 1.4" (37mm)
Distance from end of crankshaft to front bearing: 1.1" (29mm)
Distance between mounting flanges: 1.8" (45mm)
Distance/bottom of mounting flanges/top of cylinder head: 3.6" (91mm)
Distance between pull start and crankshaft end: 4.4" (113mm)
Distance between pull start and front bearing: 3.3" (84.5mm)
Outer diameter of exhaust opening: 0.65" (16.5mm
the only problem with LRP is apparently its getting really hard to get parts for if you want the exact duplicate pretty much go with the xtm 457 pro truck engine it has the same specs as the lrp and looks the same and goes for around $160.00!! and still can get parts everywere for it.. i have one and man all i can say is its a power house of a engine!! it has a claimed hp of 3.8 which is insane!! wheelies on demand all day long lol or i've heard the surefire 32 is a awsome engine as well!!
