Question on the back plate
jeff B
Is the back plate and roto start mounting all the same on nitro engines ?. Have a savage and just purchesd a OS 28zx max it did not come with back plate and was wondering if I could use the one of my hpi f4.6 on it.
No I doubt that it is the same, if your OS engine has no pullstart or roto unit on it is entirely possible that it is a bump start engine only... got a link to your purchase so I can see if it is capable....?
if it is This :ercm: it will not work for the Savage
http://www.osengines.com/engines-car/osmg2074/index.html
Has nothing just a cap over it. It's model 13280 I believe
That :ercm: is not capable of using a pullstart or a roto unit if you look closely at the crankshaft you will see it is missing the little nub needed for it to use a pullstart or roto unit, so unfortunately that :ercm: can only be started by a starterbox by turning the flywheel
http://www.osengines.com/parts/xr12830.html
scroll down and click the pic of the crankshaft you will see exactly what I am referring to....
