OS .30 VG(P) ES Pullstart Conversion?
Rep99099
Hi guys, the used Savage XL I got had this engine in it with the rotostart:
http://www.osengines.com/engines/osmg2078.html
I want to convert it to a pullstart. I originally bought this pullstart:
http://www.amainhobbies.com/product.../7258/n/OS-Recoil-Pull-Starter-Body-21VG-30VG
But it does not fit...only the 2 right side mounting holes line up, and pullstart is not deep enough (shaft on engine too long) there is an 1/8" gap between the pullstart and the engine plate the shaft on the engine bottoms out and doesnt allow it to sit up tight.
Can anyone help me here?
rep you probally have this starting shaft
because this one is for when you use the roto start
http://myatomic.com/catalog/viewsku?sku=OSM23912210&q=23912210
it is Length: 1.21"
and you probally need this one
http://myatomic.com/catalog/viewsku?sku=OSM23612050&q=23612050
Length: 1.03"
Maybe some one else can confirm it but that is what i think is wrong
OK thanks bud!
But Also the mounting hole son the pullstart are different, its got 3 mounting holes but the plate on the engine has 4 mounting hole sin all 4 corners, the pullstart has 2 mounting hole son teh right sid ein teh corners that would line up but the 3rd on the left is more toward the middle which serves no purpose, this is the correct pullstart though?
I will sell you an OS30-VG compete, with new piston/cyl and bearing, for 120.00 (not seen fuel since rebuild) not sure on what shipping would cost, like to split that
I've got a good picco 30 here, just want to convert to pullstart, i don't want to spend $$ on another engine I don't need... I jsut spent a chunk for a picco 28 🙂
i was able to drill out the stripped screws and put some calipers on the shaft and it does measure 1.214", so i will order up that 1.03" shaft, but I need a shorter One Way to go on it also, I cant seem to figure out what I need...
