New Picco Coming. Looks Sweet.
kvnnets
Oakville, Ontario, Canada
Here are the specs.
This is the Picco .28 JL Team Turbo Engine from Ofna.
FEATURES: Designed for off-road truggy and truck applications
Modified for greater corner exit power and high top speed on long
straights
Composite body carburetor with 8mm opening
ABC construction "A"luminum piston with a "B"rass cylinder liner that
is "C"hrome plated
Larger intake ports for more torque and modified exhaust port for
more RPM
SG (pilot) type crankshaft
New CNC cooling head design
INCLUDES: Picco .28 JL Team Turbo Engine, slide valve carburetor, exhaust
gasket, instruction manual and parts list
REQUIRES: Fuel with 10%-30% Nitromethane (20% is recommended) and a lubricant
content of 16% or more
Turbo Glow Plug: OFNG5106
Air Filter: OFNG1137
Exhaust system depending on application
SPECS: RPM: 37,000
Claimed Horsepower: 3.4
Ports: 7
Stroke: 0.69" (17.6mm)
Bore: 0.72" (18.35mm)
Weight: 12.3oz (350g)
Distance Between Mounting Holes Same Side: 0.83" (21mm)
Distance Between Mounting Holes Opposite Side: 1.5" (38mm)
Height from Bottom of Crankcase to Top of Cylinder Head: 4.4" (111mm)
Height from Bottom of Mounting Tab/Top of Cylinder Head: 3.8" (96mm)
Height/Exhaust Port Center to Crankcase Bottom: 1.8" (47mm)
Width at Mounting Tabs: 1.7" (44.2mm)
Length from Backplate to End of Crankshaft: 3.7" (94mm)
Length from Backplate to Front Bearing: 2.5" (64.5mm)
Carburetor is factory adjusted. Only very small adjustments should be
made. Ofna does not state specific number of turns for carb
needles.
My question is did they fix their piece of crap pullstart and piece of crap carb. Any pics?
This is the only pic I have.
I don't think the JL comes pullstart. Ill just give my money to robin for mods... that is the 8mm fixed carb that is on the newer ofna picco 28
well i like the black look but if its bump only its definatly not for a savy so does me no good and i honestly don't think its a new one is it? the newest picco i seen was the one with the head cut into the shape of a saw blade it lookd sick.. i think eric or jp3 linked it one night but it was bump start to... but i think i seen the one pictured before idk..... nice looking mill none the less.
That engine does not come in pull start form, it is bump only. You would need a new crank, backplate and pull start to get it to work. Sorry bud.
It would be awesome if the savage could use a bumpstart. Oh well you have to give some things up in the name of greatness.
