I've driven a rig with a popped off ball joint before. Cost me a busted cvd on my aftershock. Twice! Guess I'm a slow learner. lolBest fix that right front wheel. at least hook up the rod to the linkage point.....
I just installed the lrp 360° back plate. I'm wanting to use the hpi roto start 2 that worked with my .28 My question is now, is the hpi going to turn the right way? From the looks of things the hpi roto start 2 is going to spin the wrong way. I do have a drill but I don't want to lug that big ass thing around. Edit: It seems like the hpi roto start doesn't have enough balls to turn the .32 over. What are my options? I don't really want to buy the lrp one and have the same issues.
Hi
......my spur gear is all messed up like half of the teeth have been cut off. Any ideas why? Can any say why i damaged my spur please.
Yes have used loctite.either your mesh was too tight or too loose
-OR-
the screws that hold your motor-mount came loose which threw off your mesh & or alignment between clutch bell and spur.
are you using Loctite on your engine mount screws?
Have sorted it will let you know how it goes.
