Head gasket?
Do you have any of them. You can just run one on the Axial motors. I run the thin one on both of my axles as I have removed the thick ones.
O man that stinks bud. You will have to order more. I'm not sure if the motor can handle it with out any shims. You can put it back together with out them and roll it over by hand using the flywheel and making sure that there is no interference. Take out the glow plug before doing so, so you can get a better feel for it.
Your owners manual for the engine should tell you how many shims to run with what percentage nitro. The higher the nitro content, the more shims needed.
