That old slipper setup wi the rubber fing wich is in them pics I sent is junk n massive the usual recent stock 1s are slimmer n loads better gi you bit more room n more power n ye I noticed people av engine shimms on the newest savages n never add any FLM tvps all them answers be on YouTube vids n ye the new Hpi spurs are lot less bulky 👍👊I've currently got a HPI lightened 17t clutchbell in there - I think if I push the clutch bell out further it will expose the clutch shoes as they are just grinning through as it is already.
It could either be the FLM TVP frame that needs a trim, or the carb on the LRP 4.1 - because I can feel some rubbing there - but then there is also the FLM engine plate that needs notching?
Not sure - will get some photos to explain - I keep coming back to these engine plate shims that HPI are now offering that they never used to - is it a design thing - albeit i'm using aftermarket TVPs?
Been running solid forever. Threw in what I had lying around. New servos aren’t in yetHow/where did you mount the steering servo - I'm using a Savox and wanted to keep the rubber mounting grommets as a bit of a buffer - wondering if the cushion the rubber grommet is taking up means that the skid plate mount is getting squished.
Would it be OK to run a servo mounted solid to the TVP without the rubber grommets?
https://rc4me.us/product/m3-washer-alu/What is with the orange rings around all the screws - looks very nice by the way
