FLM Ofna 250 Mid Tank Build
Thanks for the information - is the spur gear OK to use still - just wondered why there was an update/revision - it does feel kind of light but is that a sign of an upcoming durability issue?
I've currently got a HPI lightened 17t clutchbell in there - I think if I push the clutch bell out further it will expose the clutch shoes as they are just grinning through as it is already.
It could either be the FLM TVP frame that needs a trim, or the carb on the LRP 4.1 - because I can feel some rubbing there - but then there is also the FLM engine plate that needs notching?
Not sure - will get some photos to explain - I keep coming back to these engine plate shims that HPI are now offering that they never used to - is it a design thing - albeit i'm using aftermarket TVPs?
That old slipper setup wi the rubber fing wich is in them pics I sent is junk n massive the usual recent stock 1s are slimmer n loads better gi you bit more room n more power n ye I noticed people av engine shimms on the newest savages n never add any FLM tvps all them answers be on YouTube vids n ye the new Hpi spurs are lot less bulky 👍👊
How/where did you mount the steering servo - I'm using a Savox and wanted to keep the rubber mounting grommets as a bit of a buffer - wondering if the cushion the rubber grommet is taking up means that the skid plate mount is getting squished.
Would it be OK to run a servo mounted solid to the TVP without the rubber grommets?
Been running solid forever. Threw in what I had lying around. New servos aren’t in yet
Few updates after waiting for some parts - decided to swap out the Spur gear for one off of eBay - that is the one in the middle:
No matter which way I tried to mount the LRP 4.1 I couldn't get the 47T/17T combination of Spur and Clutch to work - so have gone with a 16T Clutch Bell instead - just dropping one tooth on the Clutch Bell has created a lot more wiggle room to get the mesh just right - look at the size difference between the 17T and 16T clutch bell:
This is what the new Spur Gear looks like - seems solid and decent metal - and now the gear mesh is ok - I just don't have enough forward adjustment to get the Spur and Clutch Bell aligned perfectly - but because the Spur gear is thicker I'm getting a better contact so hopefully this will be OK:
I decided to ditch the idea of using the engine mount shims as the contact patch between the engine plate and mount is significantly reduced:
I think I can just get away without the engine mount shims as the carb just clears the right-hand side TVP - can just about see a bit of daylight through the gap:
After installing the new 16T HPI Clutch Bell - it did need these shims to reduce the amount of play - but left a small amount of play to factor in any expansion when the motor gets up to temperature:
Here are some other photos - other changes was going for the actual XL roll cage rather than the zip ties - thought this might hold up and be a bit more durable if/when the truck lands/rolls on its lid - other change is moving from the stainless steel to red fibre disc brakes:
note that the standard roll cage handle (LHS) is slightly different to the XL Roll cage (RHS)
Things left on the list of to do:
- Radio box
- Throttle linkage
- Battery mount
- Thread lock everything
- Order some new fuel line
- Order a new hex drive for the the new red fibre brake disc to slot on to
- Set the toe in/out
- Dial in the steering linkage and end points etc
- Runin the LRP
- Bash it
- Maybe sway bars - found these really make a difference with body roll - helps keep the truck planted
Made some good progress last night - got the red fibre glass brake kit fitted - there are a few washers that come with the kit - the actual brakes themselves do not come with instructions - so I found out that the bigger black washers are placed on the gearbox first - and the smaller silver washers go on last - the instructions say to add more shims if needed but the brake kit itself was fine - no extra shimming needed:
Just a word of caution - not sure if you can tell in above photo - but when testing the routing of the servo wires - the protective plastic casing on one of the wires somehow scored on some of the chassis components - the edges of the engine plate mount and the servo mount are quite sharp - they have not been smoothed off like the TVPs - so am going to get some electrical tape or something - to protect the servo wires - when the engine is running there are going to be vibrations - just a headsup
For the battery to power the receiver and servos - I'm going with this:
Its a Life versus the typical LiPo of NiMH - so the 6.6v the pack delivers is safe on pretty much all receivers - and provides a bit more punch for the servos - I tested this back to back on a Savox 1270TG with both NiMH and Life - and there was a noticable difference in steering torque.
Because the battery pack is quite compact - the battery lends itself to fitting here quite nicely:
Just need to figure out how to mount the battery and what to mount it to - am thinking mount a radio box to the left side TVP - or mount it under the FLM servo mount tray - I also would like to keep the led battery indicator strip - so if anyone has any ideas that would be much appreciaated!
So after mocking the build up - I got my rotostart and have found it is not long enough to reach the rotostart on the engine:
With the HPI standard XL TVPs a rotostart can still be used - so I have changed where I would normally come in to start the engine - and found an angle where the rotostart will reach the engine:
I'm not sure if this angle will put any strain anywhere - but has anyone else come across this before?
One more update - I'm not quite happy with the length of the hex cap bolts I'm using as I feel there should be some more thread being captured so I've gone and ordered the following sizes:
- M4 x 12mm
- M4 x 14mm
- M3 x 8mm (for the FLM servo mounts)
And I came across this video on youtube and found the exact same servo horn on wheelspin models - so waiting for this to come in so I can get the throttle linkage setup:
