Exhaust pipe in contact with roller cage clip
F-Type
Gothenburg - Center of the Universe
On my Octane the exhaust pipe is in contact with the front right clip securing the roller cage.
This isn't very good, as in the end it might risk scratching a hole in the exhaust pipe.
What does it look like on your cars?
One wonders what HPI was thinking here, the exhaust pipe is in the way on the outside and the fuel tank fastener on the inside, making it more or less impossible to insert, remove this clip.
Mine has a gap also. I have seen pictures of Octanes where the manifold has bent pushing the exhaust up against the side of the truck.
This is a picture of mine showing the gap between the exhaust and the roll cage clip
Ok, perhaps mine has got bent as well then, however that happened. I guess when the exhaust has been really hot then.
Thanks for the photo Paul!
I'll see if I can bend mine out a bit, to give enough gap to insert/remove the clip.
your manifold should have a nice gentle curve like this
