Dynamite 053
JargonBomb
Alberta, Canada
Installed this Dynamite 053 Exhaust and a few other little things a couple of days ago. After some slight tuning I'm loving the performance and sound!
I did shave off part of the header so it would sit correctly and not interfere with the roto start plate.
What did you have prior to the 053? What's better about it Perf. Wise? Better low end, high end? I'm new and trying to learn about pipes.
The dynamite 053 is a popular pipe , better sound, easier tuning, better all around performance and 1000 times better than the stock plastic pipe that comes with some of the savage rigs.....
If you notice tho it is meant for a right side and he inverted and clearanced the manifold for clearance for the roto unit and made his own pipe wire mount as stock will not work
I could not have explained the pipe better than that, thanks Jam .
I had the stock plastic pipe on before, I think the 053 is a mid to high range power band pipe? I've had the pipe for about a year now and i'm still enjoying it! I do however have to replace the exhaust gasket because one of the retainers tore it up.
