F-Type
- Location
- Gothenburg - Center of the Universe
Hi
Noticed several times today how the Octane hardly moved despite high engine RPM, especially up slopes.
Took the clutch apart, and it looked like in the pics below.
I did notice that the clutch must have been faulty assembled (by the previous owner), because when I was putting it together again I noticed the two ball bearings had both been fitted under the clutch bell, one should go under and one on top. So I guess that is the cause for some of the problems. But the very rough surface on the clutch shoes, is that normal? Considering how things works, I would have expected a rather well polished surface!?
I also noticed that the clutch bell, when refitted, came in contact with the flywheel. I had to put an extra washer in between (I put it under the bearing you see in the pic). I found that a bit strange, an indication of some kind of problem, or just normal?
Do I need to get new shoes or will these wear in again?
