justinluv949
Hello, this is my first post.
I have looked and been threw the forums many times.
I have a Savage X 4.6 nitro truck.
I’m looking to convert it with out it costing over 350$.
I want to know what you guys think about this set up.
First is the esc I’m going to use the blur savage hp unit http://www.amazon.com/Flux-Blur-ESC-Savage/Hp/B001QLFPCK
I found one for $118 new its like a take off so i guess its used.
2. The motor is a Tacon brushless 4074 2150KV 1/8th scale
http://www.hobbypartz.com/96m802-4074-2150kv.html
59.00 new.
3. Transmission. I’m going to use the flux Hp trans
I found for 41$ all metal gears.
4. Robinson racing spur gear hardened steel 48T and 12T pinion.
about 20$
5. Battery sky LiPo 5S 40C 18.5V
4400 mAh $39.00
http://www.hobbypartz.com/77p-sl4400-5s1p-40c-5555.html
I'm going to try, and mount inside the chassis on this. I'm not sure if it will fit. I need to measure this.
6. LiPo charger
Sky charger 59.00
http://www.hobbypartz.com/skychb6chdup.html
7. Motor mount I’m not sure it will work or fit. So this is my biggest question. I going to measure for it so I think it will work. Model 4140 for smooth can motor 40mm $40.00
http://www.teknorc.com/product_info...=1035&osCsid=3e03139a9e9675ac6b1acf8b3239fd5a
This is about it I’m sure I will need more little parts and bracts and screws.
Total price about $376 without tax or shipping so its more like $410 with everything.
Question do you guys think this setup will work and what do you think the first thing to break will be, and how fast will it go.
I’m looking for speeds between 40-50 mph.
Thanks guys for all your help!!
59.00 new.
about 20$
4400 mAh $39.00
6. LiPo charger
Sky charger 59.00
