Can anyone confirm this?
savageweasel
N.E. Ohio
never heard of it fitting but this is the place that you will find your answer. +1 on the nova head!
ryugaiden05 that would be greatly appreciated if you could compare them.
And for the nova head - I don't have any troubles with the temp. I stripped out the glow plug hole and in need of a new head. So i thought the axial would be the best choice in case it happens again.
My local hobby shop rocks, he told me either way I go hpi head or axial head & button for $30.00 plus tax, but i hate to have him order it then have to send it back if it won't work.
:resp:
:resp:
Careful with this it can drop shavings into the mill 🙁
I found my old 4.1 head and my old axial head and they do not match up. i am sure the 4.6 head is slightly larger than my 4.1 put not 100% sure. If you just stripped the glow plug hole, I would just replace that part.
On the K4.6 it does not have a changeable button.
How it got stripped was my fault :duh: - with the head off.
Rear bearing went, sort of, the keeper fell apart and must of melted and fused to the insides of the motor and burnt out the plug. Replaced the block & went to change the plug and bad word.
And for nova products I also have there motor mount and love it. :resp:
