Wow. Looks like it'll probably retail at around $600.
The Savage XL – Extra Large Size and Mega Power!
Check out the new addition to the Savage line-up! The Savage XL is the extra-large, extra-tough and extra-powerful big brother to the Savage X monster truck. For improved stability and handling, the Savage XL has a 55mm longer wheelbase and a 25mm wider track. With a longer wheelbase, wider stance and huge 5.9cc (.36 cubic inch) engine, the Savage XL is ready to rock and roll right out of the box. The HPI design team added strategically strengthened hop-up parts to tame the massive K5.9 power for unmatched durability. The Savage XL soaks up the rough stuff with ease because it’s the biggest, toughest, and most powerful Savage ever!
The wide front grill and huge headlights of the GT Gigante body merge with the flared wheel arches front and rear for a huge ‘wow factor,’ adding to the impression of huge size and strength! The large Terra Pin tires fit the body perfectly for a scale monster truck look that’s sure to intimidate the opposition at your local bashing arena! But the Savage XL isn’t about just looking great, the HPI designers went all-out to make sure it performs as good as it looks!
Size Does Matter...
Bigger in every dimension than the standard Savage X, the Savage XL is longer, wider, taller, more ground clearance and tires that are nearly 7" in diameter! It’s based on the practically indestructible Savage X chassis and features durability upgrades like thicker 3mm TVP chassis plates, 3mm alloy engine plate, machine-cut steel differential rings and pinion bevel gears, steel spur gear, heavy-duty clutchbell, extra heavy-duty dogbones, larger diff outdrives, machined brake hub, dual fiber disk brakes and much more!
Extra-Long Alloy Chassis
To get the long wheelbase of the Savage XL, the HPI designers developed all-new extended TVP (Twin Vertical Plate) chassis made from 3mm thick 6061 aluminum. 6061-series aluminum is light and strong and provides the strength for stretching the Savage platform to its limits! The chassis has Savage XL logos etched into the chassis to really make it stand out! The engine is fitted to a one-piece engine mount with an extra-thick 3mm engine mounting plate. These are the thickest TVP and engine plate parts ever offered on a Savage monster truck, giving the Savage XL the strength to withstand the torque of the massive Nitro Star K5.9 engine.
Huge Terra Pin All-Terrain Tires
The large Terra Pin tires and TVP style chassis help give the Savage XL massive ground clearance of over 3 inches, allowing it to go over obstacles that would stop other monster trucks in their tracks! The new Terra Pin tires stand tall at nearly 7" in diameter to soak up ruts, bumps, and rough landings. The tough spike pattern makes the Terra Pins great in grass and loose dirt, while the chevron center pattern give them directional stability on the harder surfaces. The tall sidewalls provide extra shock absorption and allow the tires to grip as they roll over obstacles.
Three-speed installed, too.
