Post your tire and rim setup pics
That’s funny my silver body and purple with flames are by Ziekle racing and they do top notch work!!
Got a new set of tires from Team Energy R8MT. It’s got the same diameter as the Terra Pins but these are the low profile type:
Traxxas talons... while I sort out my tuning issues. Figured less rotational mass would help figure out what's going on.
Curious how those rims hold up. They look a bit brittle, but I like the tread pattern. Aggressive, but large lugs that will hold up to skate parks, yet get good bite in grass/dirt as well.
That was my thoughts when they turned up to, there is not much give in the rims ? will see what happens when I get to launch it on some big jumps LOL
How did you get them to fit... 17mm hex?
I like the look of those wheels and tires!!
I use the wide axle stubs and I modified some cheap "extenders" I got off ebay. Pretty sure I had a thread with this, but I'm not finding it at the moment... since it deals with "tires" sort of, I guess here is fine too. lol!
My flux was used and came with the silver hub extensions on it on short stub axles. They fit horribly and I replaced them with the hpi long wheel stubs and hpi 17mm hex's/flange nuts. Then I snapped an axle off at the threads, so out of a bit of desperation, I decided to try and make those hubs work, but be better supported. I cut off just enough so that where the hex pin goes would be captured by the wheel. Was a pain with just a hack saw and a dremel, but I got them all pretty close. Drilling the hole in the right spot was the hardest part, since all I have is a hand drill. I used shims to take up any extra slop. 75-80% of the hub is supported by the extended shaft. So it's far stronger than just throwing a set of hub extensions on.
This was the one I broke the threaded part off of:
On the rest, I had to drill a hole in the cap/nut so the threaded shaft could stick through a bit:
I didn't take many photo's of the ones on my X as they are the same as the ones I got for my Flux HP, just red:
Turns out, these hubs fit traxxas keyed hex's, so that was a happy accident. Usually I use an exacto to cut the little nubs off in the hex's to use them on standard flat hex hubs.
These are the hubs, or ones just like them:
https://www.ebay.com/itm/1-Set-17mm...m-Aluminum-For-1-8-HSP-RC-Car-US/382855457218
To me, it was worth $10 to experiment and I'm glad I did. No more busted cap nuts!
HPI changed them along the line. They used to be a lot thicker and more solid. Then they became much thinner and I started breaking them. I use them on my nitro revo's as well with traxxas 17mm hex's that I cut off. I used the flange nut as the traxxas hex/hubs would wear themselves out on the threads and wobble all over the place. So I'd cut them off and just use the hex with these.
I did find some stronger ones from axial, but they don't thread on as far. The threads don't start for 1-2mm into the flange. They worked ok though on the savage. I never tried on the revo's as I still have a few hpi nuts left.
HPI Z680 old - new - axial 31087:
@carldav can you please show me how in the world you managed to get your savage to have such a lcg!?
I'm wanting to turn mine into more a of truggy style racer and what you've shown above is EXACTLY what I had pictured in my head!
Traxxas Sledgehammers ?
Baja Pro-Line Bow-Tie on a Savage XXL
HPI Super Mudder tires with RPM revolver wheels. Stablemaxx offset.
Ofna dish wheels with 1/2" offset and losi raminator tires.
Proline Badlands MX38 3.8" with F-11 Black 1/2" Offset
Those are a lot larger than I thought they were... didn't they kind of make those for the maxx 4s/stampede 4xs4/rustler 4x4?
This one is from the traxxas Maxx, 5.6” tall in diameter
Dboots 4s LP wheels tires
My lovely car my pride and joy. . .
I use:
SWEEP TERRAIN CRUSHER BELTED TYRE ON BLACK 17MM WHEELS 1/4 OFFSET​
Like it?
These are the rims & tyres I run on my trucks.
Truck 1 : Fastrax Eagles, 6 Spoke Black 166mm Dia 108mm Width 17mm Centres 1/2" Offset
Truck 2 : ZD Racing 6 Spoke Black 166mm Dia 108mm Width 17mm Centres 1/2" Offset
Truck 3 : ZD Racing 8477s Black 150mm Dia 77mm Width 17mm Centres 1/2" Offset
Truck 4 : ZD Racing 8744s Black 150mm Dia 77mm Width 17mm Centres 1/2" Offset
Truck 5 : ZD Racing 8744s Metalic Red 150mm Dia 77mm Width 17mm Centres 1/2" Offset
Truck 6 : ZD Racing 8744s Metalic Red 150mm Dia 77mm Width 17mm Centres 1/2" Offset
Truck 7 : HPI GT5 Chrome/GT tyres 160mmDia 87mm Width 14mm Centres Offset N/A
Truck 8 : HPI Dirtbonz Soft Compound 150mm Dia 85mm Width 14mm Centres Offset N/A
Truck 9 : Havok rims/ Terrhex tyres 150mm Dia 85mm Width 17mm Centres 1/2" Offset
These are my spare ones.
Gazzman, i like the parts on your cars they look trick especially this one: Truck 6 : ZD Racing 8744s Metalic Red 150mm Dia 77mm Width 17mm Centres 1/2" Offset
You should get this suspention:
