Battery pack for save xl 5.9 nitro rtr truck
Kellyw
If money were no object, what hump battery pack that provides the best performance for savage xl that will fit? What starter box should I use regardless of budget for the savage xl? I also need a great battery charger regardless of budget. I want to get rid of roto start on the savage. Thanks for any advice.
If you want electric start, your pretty much stuck with a roto of some sort on the savage. Otherwise, it's pull-start. The flywheel isn't exposed for a bump start.
The best receiver pack type would probably be a 2S LiPo with a BEC that drops the volts down to 6V, unless you have electronics that can handle 7V+. Short of that, the cheap intelect 1600mah 2/3A hump packs work fine for me. If you go with LiPo, you will need a LiPo charger. If not, there's no need to go nuts with a NiMH charger as you don't want to really charge a receiver pack at more than 1A anyway. Either way you go, it's not a "money is no object" kind of thing because the packs are small, so they don't cost much and a charger that can charge either battery type at 1A or 1C also doesn't cost much.
There are quite a few traditional NiMH hump packs here:
https://www.rcplanet.com/search-results?q=6v hump&page_num=2
Appears they include a few LiPo packs as well. I don't know what LiPo will fit, but pretty much any 2/3A NiMH "hump" pack will fit in a savage receiver box.
This BEC will have plenty of current to drive two servos, but it requires the $20 castle link to adjust the output voltage:
https://www.rcplanet.com/radio-syst...cc-bec-10a-switching-regulator-cse010-0004-00
Remember though, a bec is only needed if your wanting to use a LiPo pack.
Or, you can go with a cheaper generic BEC that has a voltage pin on it. I use a cheap one in my stampede because the castle esc only puts out 5v. Something like that won't handle dual high power digital servos at full capacity.
A charger like these would work for either NiMH or LiPo:
https://www.rcplanet.com/chargers/c...ra-50-multi-chemistry-lcd-ac-charger-rce2850/
https://www.rcplanet.com/chargers/c...dc-charger-prophet-sport-plus-50w-dync2010ca/
Or you can find something more economical that is type specific.
Forgot about those. They have lower charged voltage than LiPo. Don't those charge to 7.2V when fully charged though? Still a bit hot for a receiver/servo that is built for 6V. Do you run a BEC or voltage regulator?
They only charge to 6.6v. I don't run bec or regulator.
