Charger same as battery?
NitroNation
Mister QUESTION with no SEARCHIES
I just bought a savage xs off someone and there is a duratraxx onyx 5000mah battery included.
Can i charge it with any LiPo charger or doesnt it have to be duratraxx?
is the battery also a LiPo ? if so most any LiPo charger will work, remember always balance charge also.... good luck with ur new truck
What's the balancing wire and where do I find it? Where do I put it too?
first things first, IS IT A LiPo or is it a NiMH type battery... and a couple pix of what ya have would help alot
A LiPo requires a balance lead, a NiMH does not....
So its a 5000mah LiPo then. The big plug with the two wires is the main plug/wires, and the small plug with the small wires is the balancing wire. Make sure that is plugged into the correct port on the charger when you charge it.
And make sure its set to LiPo, up to 5 amps. Then you're good to go. Brand makes no difference
Ok that's cool. Thanks guys..... I got a used savage xs and looks really good except for one thing.... I don't think the fan on the ESC is working. I don't see it more and don't hear anything... What's could be the problem???
I found a good one check it out and tell me what you think guys.
eBay item number 330969229827
NO! Get a better one with adjustable amperage. You can spend $35 and get one that will charge up to a 6 cell LiPo, .1 to 5 amps, LiPo, NiMH, nicd, pb.
Like this one. Definitely not a high quality charger but it does pretty much everything and it seems to work good. (I just bought one recently)
http://www.ebay.com/itm/US-Seller-i...Control_Parts_Accessories&hash=item231fae9203
i cant buy this one....i have to pay 30 bucks extra for shipping because i live in canada....🙁
this store is really close to my house....any good chargers??
http://hobbyhobby.com/store/
I don't hav the money I need one that's a little bit cheaper than this to be honest.
Well I suppose the Traxxas one will work, but I think you should find one with some more features. I can't tell you how many times I've said, "man I wish I had gotten the one that does THIS also"
A good charger is definitely worth the time and money, you just cannot rc without a good charger that charges all different kinds of batts. 🙂
i found this one....is it good???
http://www.ebay.ca/itm/New-iMAX-B6-..._Parts_Accessories&hash=item53f8ed311f&_uhb=1
or this one is even a little cheaper....
http://www.ebay.ca/itm/Battery-Bala...o_Control_Vehicles&hash=item460a4f5657&_uhb=1
or this is even cheaper...
http://www.ebay.ca/itm/Imax-B6-2-6-...t=Battery_Chargers&hash=item2c67eaecbf&_uhb=1
i just bought the imax b6 but i noticed it doesnt come with the wall plug..... how am i supposed to start it???? need help please...
UUUMMMMM maybe caz is only a dc charger....... you will been a 12 v battery or a power supply to operate it correctly......
You will have to know the post and barrel size for the connector as well. Hopefully you have a caliper you can use, because even .1mm off can get you the wrong connector.
We know, that's what Jam and I are talking about. You posted that earlier.
:lmao:
and ya are still gonna need a power supply and it looks like the balance plugs for that unit...... otherwise looks like a good unit for your needs
i didnt understand your last post......I'm saying i need an power adapter. where can i find one that works with my charger/balancer?
You can get them all over the place. What you want is a AC to DC transformer. It looks like a package attached to an AC wall connector. Then it has a cord attached to a barrel connector, which plugs into your charger. You need to know what voltage your device needs, which it looks like 12VDC. And you will need to know which barrel connector it needs, as I was saying in my above post.
