Roto start problem
well don't give up,were all here to help.Someone will post some help shortly I'm sure !! i don't know to much about why it would do that if you have replaced the one way already so I'm sure someone will be here to help shortly
And welcome to the forum!! your in the right place if your in need of help!!
WOW, i can really help you man, The exact same thing happened to MINE. So, when you take the back plate off, there will be a hole in the rod at the bottom of the rod. In that rod you should find a small silver metal ball with two or one springs behind it. If you cant find the ball, don't worry it is in there! What usually happens is with the savage, it uses two springs in the rod then the metal ball. Usually those two springs mesh together and combine into one. Take it out and see whats going on there. There may be two springs in to one. If there is, seperate them, and reinstall them back in. REMEMBER longer spring goes first, then the short one, then the metal ball. This should fix your problem
Thanks ill give a try. I hope this fix it
yep it for sure will I'm sure. I was worried too, but i found out that the two springs meshed together. Also make sure that when you place the ball back in, make sure its sticking out a bit, because the back plate has a small hole in it that comes and grabs and holds on to the ball when you spin the roto start
here is a picture
Where the little arrow is pointing is where the metal silver ball and spring go into the rod
my engine is not like that one it says 30vg on the side and has a blue top.
ill take a picture today and post it.
yep i know, but that picture is for refercence. Almost all of them look like that on the inside, with the hole in the rod and a silver metal ball with a spring or two
i didnt see any of what you told me but i fixed it. the bad part is that the engine broke somehow since the day before.
what i did was take a regular nut and drilled a hole on the nut and the shaft and then put a pin that worked really good.
I'm going to buy a new engine for my truck what should i buy a hpi 4.6 or 5.9? and will it fit on my savage?
thanks
