MN Savage Racer Project
B-Woo
So I started this build about this time last year, I finished it about 6 months ago. Long story short, long time ago I got an old savage 21 in a trade for an Xbox 360 (POS). Went to the hobby store ask what I could do to make track ready. Then the manger and I got in to a heated argument about how I should have bought a Revo. Scraped the Savage 21 and started doing research. So a year after planning, half a year of building… Here we are.
Hpi Racing Heavy Duty Servo Saver Spring
Hpi Racing Machined Bulletproof Diff Bevel Gear
Hpi Racing Universal Dog Bone
Hpi Racing Heavy Duty Cup Joint
Hpi Racing Savage Suspension Conversion Set
Fast Lane Machine Savage Servo Mounts
Half-Up 1/8 Truggy 3.7" Rims
Proline Maxx Road Rage Tires
Hot Bodies 76mm Big Bore Shock Springs (Orange - 76Gf)
O'Donnell Battery Box Set (Team)
Fast Lane Machine Savage Motor Mount
1/8th Clutch Bell, Titanium Nitride Coated
8X16X5 Yellow Seal Bearings
Savage XL Yellow Seal Bearing Kit (Complete)
Hpi Racing Titanium Idler Shaft
Hpi Racing Titanium Gear Shaft
Hpi Racing Titanium Drive Shaft
Dynamite Purple Universal CVA Shaft Boots
HPI Body Mount Set
Mugen MBX5 Wing Stay
Mugen MBX5 Wing Stay Brace
Mugen Buggy Wing (Black)
Fast Lane Machine Savage Steering Brace
Hpi Racing Savage lightweight Drive Gear
Hot Bodies Big Bore Shock Rear Shock Set (112mm)
Hpi Racing Savage Front & Rear Sway Bar Set
Xtream Racing Savage Carbon Fiber Suspension Brace Set
Hpi Racing Composite Gear Box Bulkhead Set
Ascendancy Racing Effortless Racing Clutch Kit (34mm)
Dynamite Platinum 086 High Speed Inline Exhaust System
GH Racing Large Aluminum Fuel Filter
Motor Saver Savage Big Block Air Filter
Hitec 7965 Digital High Speed Servo
17mm Hex Hub Conversion Set with UV Joints
Lunsford Titanium Upgrade Combo Kit
PRC Carbon Fiber Hpi Savage Lower Bulkhead Plate
PRC Carbon Fiber Hpi Savage LCG Shock Tower Kit
PRC Carbon Fiber Hpi Savage Extended LCG Chassis & Skid Plate
PRC Carbon Fiber Hpi Savage 21, 25, X, SS Motor Plate Kit
Full Force R/C Hpi Savage 7075 Brake Hub Savage
Pro Tek NiMH AA Loose Battery Cells (4) (1.2V/2500mAh)
Pro Tek 5-Cell 6.0V NiMH Intellect Receiver Hump Pack
Racer's Edge Aluminum Antenna Mount (Purple)
Racer's Edge Aluminum Pro Adjustable Hitec Servo Horn
Ofna 125cc Stone Filter Fuel Tank
Ofna Servo Linkage Kit Purple
Ofna Clutch Bell Shim Kit
Ernst Charge Receptacle Futaba J FM
Edit Titanium Cross Shaft for 4 Bevel Gear Differential
Hot Racing Kevlar fibers diff gasket (2) savage
Hexcrews Hpi Savage XL HexHeads Armor Plated Screw Kit
GPM ALUM. Throttle Bracket
Losi Turbo Head Conversion
Spektrum DX3S 3-Channel DSM Radio with Telemetry
Hitec 7955TG Digital High Torque Titanium Gear Servo
HPI GT Gigante Truck Body
Dynamite Platinum .28XP with Pull/Spin-Start
Custom PRC Carbon Fiber Hpi Savage Radio Plate
Custom PRC Carbon Fiber Hpi Savage Mugen Wing Mount Plate
Hot Racing Aluminum 6x6 Stand-offs
Axial 7x15 Aluminum Posts
Let’s just say I had lots of fun building this from scratch.
Pics will be up when i learn how to post.... sorry 😉 for the Suspense.
Good looking ride bud! Nice choice of parts rockout
Thanks for sharing!
Nice looking truck! I'd like to see the look on the hobby shop guys face now!
Stock revo vs. one bad#@& ready to race savage, that guy would not have a chance! Nice work!
"hey what shocks , towers and tvps are you using ?"
PRC tvp's ands LCG shock towers.
"How many minutes are you getting with the tank?"
About 7, the DPS seems to use less gas now that it has a turbo plug.
"So how much was it?"
about $2,200.
The fuel tank mounts to the original mounts. They fit the fuel tank just fine but i have to grind them down a bit to fit the PRC chassis. The PRC tvps seem to a mid-tank mod only kind of frame.
No Vids, i don't have a video recorder.
Nice build bro, Very clean and looks light and fast. How well does the CB TVP plates hold up? I bash more than race. It is a hard choice considering they cost just as much as the FLM but, they are cooler looking. lol I am more worry about strenght than lightness.
Nice truck. I have a 1000.00 dollar Revo it was my first truck and now I have two Savage and I'm building another one so let that speak for itself. HPI Rocks!!!!!!!hpisfoldskool
How are the rear D8T shocks on the savage? Are they better than the Hpi big bores? And how do they hold up to bashing?
They hold up just as well if not better then the FLM TVP's. They are a little more forgiving because they have the ability to flex. I love them, i would replace them if they broke (prob never will), or put them on another build.
Very well, there are very few tracks in MN, all of which are two hours or more from where i live. I mostly bash right now because i don't have time to get out to the track. The D8T shocks hold up just as well. I fell it will be harder to bend a shaft with the because their shorter, but you give up some of the handling characteristics of larger you want for bashing (i get Chassis slap on mid-sized to large jumps).
Here is a pic of my last light Bash
and a Vid
Also how well do the CF shock towers flex I had flm towers and the first flip broke my diff housing, I just want the to flex a little
They are thicker & shorter then the TVP's so they will not flex any where near as much. They will not produce the results you want, however the FLM shock towers will bend far before the PRC's Snap. I'd say stick with the FLM shock tower because you have them, but try the Flux bulkheads.
So I have finally burnt out the engine. I will be needing a new one. I have put a lot more upgrades into it but I have started a new project for my brother. I'm building a basher. So that means I need a cheap engine. Any ideas?
