rim holes or no holes
chbronco
I run, rpm , maximisers glued, there are air tight,should I run holes, water do you guys do?(no doubt more bouncer air tight, but less water in)
Its up to you but, if they were my tires I would put rim holes because then if that little bit of air did escape I wouldn't have a sucked in tire or flat sided tire.
this next comment might cauze some controversy but:
if you're gonna vent your tires, get a hole-punch and vent the tire not the rim.
centrifugal force will throw the water (& dirt, debris) out the hole in a tire, but never out the hole in a rim.
+1
I have put 4 vents in my rubber for years now. I even go as far to tape over rim holes.
I agree with frddyj. I hole-punch my tyres even if the wheel is vented.
+1
+4. When I first started looking at directions with HPI trucks. I found this in the europe site.
http://www.hpieurope.com/tv13/ <-- Racing tips from a world champ.
Since then I have followed his recommendations when ever I do my tires.
Yep four holes at 12,3,6,9 in the tires. I stager them from one side to the other on the tire. I use a leather hole punch to make them.
