Hyperion G3 6500 Mah
frddyj
boston
SNAP on the batteries... I'm in the process of soldering my connectors...
I heard those chargers come highly recommended. Is a decent charger really worth it? I usually don't need a really fast charge because i just charge the night before. Is it worth me upgrading?
And how much do one of those set you back?
]-[0pa]0ng;167623 said:
Is this your setup? I have the muchmore power supply. Team charger with a sensor
Yeah thats mine & i bought the muchmore p/s on your recommendation :resp:
Oh heeel yeah. i had a hyperion 601 just for my hump & glow ig. this 615i duo net 3 model will "sync" charge & balance the packs & charges up to 15A per side O.O.
this is a matter of personal preference but the hyperion packs can be charged up to 5c but i have 6.5A packs so the fastest charge i can give it is <3c. still kicks butt tho.
you can have this charger for $250.00 shipped these days. Think i paid $130.00 shipped for the p/s. Money well spent imo, I'm very happy with the whole deal.
How many amps is the powersupply. I am in the market for one for carpet season but need to run 4 chargers on it.
p/s is 24A 16V. not sure it has enough jam for 4 chargers. they say it can do 2 chargers or a charger/tire warmer. it has outputs for 2.
fred do you charge above 1c? sweet set up.
yeah. theyre 6.5A packs & 15A max & i do max charge so its just a little over 2c
Frdyy, can you clear something up for me...
Considering these are 6500mah packs. Would i charge them at around 6 amps? I am a little unsure, when they say "can be charged at 5c" what amp rating is that considering the specs of this particular battery?
1C is 6.5A. 5C is 32.5A. For this particular pack. If you have 5000mAh cells 5A is 1C, 10A is 2C and so on.
thanks a lot for the help... i just had a look at my charger and looks like i can only charge at a max of 5amps anyway.
Looks like a new charger will be where ill be spending some money next
I have the same packs and same charger. Tried charging the packs at 13A each with no issues.
Powering the charger with a industrial switching power supply for network devices pushing 24V at 23A.
That PSU will handle two Hyperion 0615 Duo3s with ease.
Look for a HP J4839A if you folk are interested in getting one.
DF
