i have considered but i have 2 Losi Ten-T although Nitro that fill that bill for me. One of the biggest reason's I'm looking is because I have a couple of the 1/16 Brushless Traxxas and they are a blast. And i can run them in the neighborhood without disturbing the neighbors. I want something i can race around in the street and the greenbelt but can also take to the local track when I get the chance plus i would have the nitro to run it against as well at the track when i go with my buddies.Have you thought about a BL Buggy or truggy? They are tough as nails and it is fun to have two diffrent types of rc's? Not saying you shouldn't get a flux Just putting out other ideas too.
1. whats a reasonable priced LiPo that will run it stock without any issue's. I don't want to go cheap and dangerous but i don't want to get too much battery either. what about Parallel configuration's
2. can a stock Flux do back flip's
3. whats the first part I am going to break ?
Stock flux will only run the packs in series & its what you want. you don't wanna go lower than 4s & 2 x 4s packs wouldnt fit your stock truck.what about Parallel configuration's
Like b/r said only if you get the castle link & adj start power2. can a stock Flux do back flip's
i'm a bit curious about this myself. Mine was a diff but i dint have the bullet-proof diffs.3. whats the first part I am going to break ?
Nope, don't be. We're all learning these new trucks together. Few of us got a little head start on you, but we'll all help each other out 😛eace:I'm confused. and embarrassed.
keep hearing get "2's , 4"s, 5's" but it means nothing to me. I have read the stickies on electronics and still cant find clarity. Do I need 1 battery or 2 and what specification should I get.
Let's clear up the "S"
a single LiPo sell is 3.7v. The "S" means how many LiPo cells are wired in "series" when you wire LiPo cells in series, it combines the voltage to give the flux the jam that you see.
when you shop for LiPo cells, savages will (most commonly) take 2 x 2s or 2 x 3s packs.
a "2s" pack has 2 LiPo cells wired together "in series" inside the pack (2 cells x 3.7v = 7.4v)
a "3s" packs has 3 sells wired "in series" (3 cells x 3.7v = 11.1v)
when you put 2 x 2s cells on a savage, the esc combines them "in series" so you'd be running 4s (4 cells & 3.7v = 14.8v)
2 x 3s packs = 6s or 6 cells "in series" or 22.2v
Very Important- I bought Hyperion Lipos for a few reasons, but they discharge at 35c constant. DO YOURSELF A FAVOUR and don't buy packs with less than 25c discharge, it could result in fire.
ok so the C stands for cells what does the P stand for. I thought it was the number of 2s packs I should run but looking at the discriptions online it says things like 2s 2p 35c so its 2 cells with a discharge rate of 35 but whats the P ?
C doesnt equal cells. the "C" denotes current and lets you know how many amps the pack can be safely discharged at for a given period of time.
So, if you have a pack with 5000mah (or 5 Amps) capacity and C-Ratingof 25C, it can output 125Amps for whatever time period the mfr. states.
25c x 5A (5000Mah)= 125 Amps discharge
My packs are 35c x 6.5A (6500Mah) = 227.5 Amps discharge for one hour :jamout:
"S" = the number of cells wired "in series"
Yea that was a TYPO think I'm clear now just need to pick a brand
I'm having very good luck & satisfaction with hyperion.
So Man this thing is a beast. I couldn't keep it off its back running 2s 40c 5000 LiPo's... Lots of fun but I need to get it to a big park or field. What do u guys do with the receiver antenna. do u shorten the mast and put the excess in the box. I ripped a big hole in the protective coat and really don't want to risk it cutting
Lol man, glad your diggin' the flux :jamout:
if you have that long stock AM Antenna you can
Yes it is the 2.4 its much longer than the other 2.4's I have in my other cars. most are like 3inches this is almost as long as the AM/FM antenna
