I came across this today and wanted to share it ( i don't know if its any good since i did not try it myself, but i was told it does the job)
Remove the glo plug and air filter fitting at the carburetor.
Spray a second of WD-40 into the top of the cylinder through the glo plug hole.
Spray a second of WD-40 into the carburetor with the throttle in the open position.
Use roto start to spin the motor 5 to 10 seconds.
Repeat the sequence again.
Reinstall the glo plug and air filter and you are ready to run whenever.:smilieflush:
