@Sparky, that’s good to hear. I'm glad you have it controlled. Yeah, I've tried to increase the engagement level, spring down, heavier shoes, heavier flywheel, tails with reduced pre-load, loosened the slipper, etc. (all phases of schemes of an early engagement)
The result is always the same in that instance. The engine stumbles due to the amount of draw in the engine at the low RPM range. It’s not
as bad if I run in low-bite but the draw is still there (only a little further in the range).
Consequently it's a catch-22. I can't tune it when the clutch is engaged too early. So if I get the clutch right (matching the engines RPMs) Otherwise the engine is overloaded. So it’s a choice between it being drivable or being tuned at that level of power.
As noted there are many things I could do to combat it. I’m confident weight (lack of) is playing a role. I am a weight phreak when it comes to this. so I’m confident if I armored it up the weight would allow me to engage earlier but I spend a long time getting it light and durable. I could also lower the CG
I'm sure it's another reason I can rock it with that F4.6 I case modded, when using the right torque or mid-range pipe (2090/2013/2053 all do well). Reducing weight adds RPM figuratively speaking.
Finally, regarding length, I know nothing about that XL. I did extend the wheel base a few years ago using the IRC extended chassis but I’ve since switched due to the inability to access the idle stop on that Nova 24069 carb I like. Anyway, good stuff. It's all about getting the truck to what we want in the end.
