Will Savage XL Transmission bolt into a Savage X?
Yes, they have used the "X" style case for many years now in all of their Savages. The only difference is the gearing.
I see no reason not to run the same gearing... I think I read the main difference between 2 and 3 speed is a slightly lower first gear anyway.....
I use a light coat of white lithium grease on the gear faces, a little goes a long way so use an old toothbrush or something similar to spread it round....
Some prefer just a light coat of oil or even wd40, I prefer grease as i am just an old school mechanic type and that seems to work well... 😀
sounds good. just put it in and got to thinking that it might be a good idea to lube the gears being they are all metal.
