No more than 6 led's on the esc and no more than 200 on the motor
If you added 20% more rpm's give or take why would you not change the gearing?
I bet if we look at the esc the caps inside are blown indicating HUGE power surges. These can be caused by improper gearing, weak battery pack,etc.
Two words. Dumb noob. So does this mean I'm pretty much S.O.L? In any case, I will.probably end up selling my 5s lipos and just stick to my 4s which are safer in my noob hands. Changing the gearing everytime I change from 4s to 5s is not very realistic. Now just hoping that I wont have to buy a new esc.
Randy, can he send the esc in & have a technician inspect it or has the warranty expired?
6- i again gotta point toward that 39t idler gear as i did earlier in post #12. I'm gonna go out on a limb and say you should consider returning it to stock whether you choose to run 4s or 5s.
It does jack your rpm but it overworks the hell outta the esc. Bankrupter and i run near identical fluxes both on hyperion 5s & my esc fan never comes on (stock idler) and his comes right on (39t idler).
jon also took the 39t out of his flux shortly after installing it for the same reason when he had his flux.
its evil
evil clown
