What engine w/ roto-start??
sinisterRC
Miami
So I am looking for an engine that will accept the roto-start sys. I HATE PULL START! These are the engines I am interested in:
LRP .28 or .30
OS. 30
Picco .28
I know you could probably adapt it on all of them but which one is the most "compatible" with the roto-start. You guys always come through!!
You can get the OS in roto form. If not, its easy to convert. All 3 are easy to adapt to rotostart.
Picco is probably the easiest. Youll need the hpi s25 roto backplate and a tc3 12mm wheel hex.
OS you would need the hpi s25 backplate and the OS starting shaft and the os easystart engine backplate if you don't just get it in roto form.
LRP you will need the HPI s25 roto backplate, xtm247 engine backplate, and the tc3 wheel hex.
First off thanks Grump, I know these questions can be dumb especially for some of you savage experts! When you say tc3 12mm hex, do you mean the associated tc3? Thanks for your help.
Could be wrong but I do believe he is referring to associated.
