Water proofing question
I second that, WD-40 is good for displacing water, not for waterproofing parts. I suggest using a balloon with a ziptie around the reciever and using some Plasti-dip to protect the servos. Plasti-dip can be found at most hardware stores like Ace(Rocky's).
I think so,if not in hardware stores look for a tool dealer like snap-on,s&k,maco something like that and they will have it or can get it.
Liquid electrical tape works well also, and is generally thinner than the plasti-dip and pretty much the same stuff. If you were set on the silicon instead of the lubricant use just silicon spray. Basically it's a tire dressing in an aerosol can.
