update on spinning wheels
hetch161
just want to say thanks for the fast responses and help from you guys. so heres where i am now got clutch on good tight and moves freely . engine has a good tune but damn wheels are moving still has like a fast idle trim is adjusted carb is closed as far as it will go . what do you guys think? don't think the clutch has anything to do with it now do think i have more adjusting on carb to go or is it the clutch, clutch not binding at all seems good , so otherwise it drives pretty good , just drives about 1-3 mph at idle speed , thanks again for the help
also there is no leaks engine has been sealed and no leaks anywhere else tank and line are good also
check your throthle end points on your radio it may have gotten hit by acident put it to 0 u may have to up your idle when u put your endpoint to 0
Stock spring that came with truck.I willl try adjusting idle more , if not that I try changing. Spring but there pretty new still.
ok its not the trim setting,not idle screw so it has to be the clutch I'm running out of options here so would it be the shoes and spriing, I'm running stock shoes and spring, do you guys think i need new flywheel shoes and spring ??? i drove it for like 20 min today engine ran good , did notice when applying brakes after adjusting idle engine would die
