Too Much Loktite!!!
jammer
Frome, UK
AHHHH!
Hey all,
i'm just insalling the new hitec servo and savage X radio box to my 3.5 ...
however I did too good a job when I rebuilt it last time and now I can't get the steering posts off the aluminium plate ... haha!
whats a good remedy for having used too much loktite?
soak it all in soapy water? meths?
I'm being a right old dunce today i can tell ya.
well you can warm it up but if its near plastic i wouldnt recommend that only thing is a to a longer screw driver for more leverage.
I couldn't shift it at all ... I tried heating it up, wouldn't budge. So I worked around it thinking that "well if I can't undo it, its not going to work loose!" 🙂
Another option is to remove the bottom plastic front skid plate and you can possably get a hold of the screws with a vice grip pliers and get it a touch loose. If you can cant get a hold of it you may need to grind 2 flat edges on either side acrost from each other.
If this fails, use a chisle put it on the edge of the screw slightly pointing in the direction or removing the screw and hit the chisle with a hammer. This will always knock stuborn bolts loose.
Good Luck.
