Tandy/Radio Shack Black Phantom
paulnewman
London, United Kingdom
My dad was clearing out his attic and told me he had found an old radio-controlled car which, if I didn't want, he would throw away.
I had a quick look and under the dust & grime it looked as if it had hardly been used so I chucked it in the boot of the car and took it home.
Turns out it is a Tandy (Radio Shack in the USA) Black Phantom, 4x4 twin motor from the 1990's running on a combination of 4 x AA batteries for the steering & motherboard with a 7.2v stick for the motors.
I do not think that my dad appreciated the need to remove the AA batteries the last and probably the only time he used it as taking off the battery cover revealed 4 objects that resembled green furry sticks. Needless to say that I spent a good hour with a combination of contact cleaner, brushes & small screwdriver before the contacts & switch looked as if they would allow current to flow to the motherboard and steering servo! Installing fresh batteries and crossing fingers whilst flicking the on/off switch saw it burst into life. I gave it a quick bench-test to confirm that it would move and turn as the manufacturer expected............
According to the manual I need to be very careful when I use it as it is a proper beast..
"WARNING: This racer can reach much higher speeds than most radio-controlled
cars. Be careful when you use the racer. A high-impact crash could
hurt yourself or others.
NOTES: Actual speed of racer is approximately 8 to 12 miles per hour. The
estimated scale speed is 100 to 140 miles per hour."
8 - 12 mph is going to be too fast for me to handle 😉😉 so I would need to do some drastic modifications to reduce the top speed and allow me to enjoy using it without fear:woot::woot::woot:!
This was probably quite advanced when new so it is amazing how far electric RC's have come in a relatively short space of time. I don't think that I will use this as I expect that there aren't many about so it will be purely decorative and I quite like it's retro look (the stickers are awesome).
Nice find!!
8 - 12 mph is going to be too fast for me to handle so I would need to do some drastic modifications to reduce the top speed and allow me to enjoy using it without fear!
I certainly hope 8-12mph isn't too fast for you......because that is quite slow. And any Savage will be much faster than that.
Ha ha, I've just read what I wrote again and it sounds like I am being totally serious about the top speed so have added some smileys to try and show that my tongue was firmly in my cheek when I posted this!!!!
I would say that my Savage will easily beat that speed in reverse whilst sliding on it's roof :LMAO-large:
Good to know! I was a little scared for you there. 😀
Does anyone know where I might be able to get hold of of an instruction manual for this vehicle? I know its old but I'm trying to get one back to spec so to speak.
I;
I've just come across one of these too but after giving it a quick clean and fitting new batteries as soon as I switch the car ON (with the transmitter on) the car bursts into life without the transmitter controls being operated. Does anyone have any thoughts on why? is it repairable?
