spur gears
well, my gear mesh is usually set right
and then after a few days, it must screw up and then i loose a spur gear
do u guys ever have to change out your spur gears?
yea i went through 2 in 1 day. its was because of a cracked engine plate. also make sure you lock tite you screws in it will stop the engine from moving around.
i have a metal spur gear and have had it for about a year now with no problems. but i would learn how to mesh your spur gear with a plastic one so if you get it wrong it will only strip the spur but with a metal one it may do alot more damage! ( i hope you get what i mean)
hope this helps 4x4
i spend a while on my geting my mesh and slipper clutch right so hopefully that will not happen!!
4x4
