Spektrum dx3 question
the one you linked is the same SR3000...and I believe they are all 2.4GHz...that should work fine...
Not all of the Rx will bind with the Txs. The newer DSM2 Rx won't bind with the older Txs. I read up on this on the Spektrum website and also was told by my LHS owner.
Hey xtreme, might want to double check it. I have the original DX2 tx running
one sr3000 rx in one truck and one sm3001 rx in another. They both binded
fine.
The sm3000 is a standard rx. The sr3001 is the pro series rx, which has an
even faster processor time. It also has a better case it is completely fuel
proof. They also make a sr3500 wich is 1/3 of the size of the already tiny sm
3000. It is also a pro series.
http://www.spektrumrc.com/ProdInfo/Files/DX3R_Instruction_Manual.pdf
Here's the link to see what I was talking about. Goto page 8 where it says binding process and read the note under the picture. DSM2 Rx are not compatible DSM1 Tx. I also found that Rx you were talking about. The SR3001comes with the module to convert over to a spektrum system in other radio brands. That's why I didn't see that one, but it can be bought seperate.
