Sparc
- Location
- Seattle, WA
I sent lj a PM 3 days ago, and he still has not responded so here goes anyways, as I have sold plenty of things here...
Sparc's Massive Savage Selloff
I moved a few months ago, to the middle of a city, and no longer have a place within reasonable distance to really let a Savage shine. I am keeping my buggy as there are a few tracks within an hours drive.
There will be another post with more parts later (bulks, diffs, big bores, trans etc...), I have a ton of stuff. If you don't see something and think I may have it, ask me. I will be happy to clean it up and list in a new post. I will be happy to arrange combo deals, at a minimum you will save on shipping.
If you think something is missing from a picture please let me know.
All prices do not include shipping. I am shipping from Seattle WA. I take paypal (non-cc only), amazon payments (preferred), cash for local dealing, or bitcoin.
I have rep here in my thread, have BST with many happy members! I also have heatware feedback from my years of selling on computer enthusiast forums:
http://heatware.com/eval.php?id=17120
Picture of everything listed (see individal listings for more pictures):
First up, tires:
4 Proline Sling Shot MT tires, mounted on white disk wheels with 17mm hex. Hexes, tread, and dishes are in great shape. I believe these tires have some water in them, and I recommend re-foaming them if you do not intend to use them in the snow. $35
http://imgur.com/a/8a2rR
4 HPI Dirt Bonz MT tires, mounted on white disk wheels with 24mm hex. Hexes are in great shape, tread is a little worn on the edges, and the dishes are good (slightly tweaked ribs). Foams are what comes with the Dirt Bonz. $40
http://imgur.com/a/SKHGT
4 HPI Dirt Bonz MT tires, mounted on factory X SS wheels with 17mm hex. 3 of these wheels and hexes are in good shape. The 4th wheel is slightly bent, and the hex striped. The tread is worn but, not flat. Foams are what comes with the Dirt Bonz. $20
http://imgur.com/a/4DJ5G
Electronics:
Castle 1717 1650kv Electric Motor (the motor from the XO-1), NEW and never been used. This motor was going to be the basis of my killer flux setup, and is literally a monster. $180
http://imgur.com/a/g75wU
Futaba F603FS 3 channel receiver. In great shape, never been used outside of a radio box. Antenna is not kinked, or shortened. This is the dual diversity version with two antennas (one internal). $70
http://imgur.com/aMlAz
Hitec 7955tg. This is a monster servo, that will easily throw the savage in whatever direction you want. It has bent more than one alu servo horn. The case is fairly beat up, and one of the mount tabs is broken (see pics). New cases are availiable for this servo. It has been waterproofed by myself but, this does not guarentee you will be able to take it swimming... The cable has also been wrapped with protective sleeving to prevent chafing. $80
http://imgur.com/a/Im4Qw
Hobbico AC/DC Auto-Charger 900. Great for charging starter batteries (NI-CD). $5
http://imgur.com/vS7SW
Engines:
HPI K4.6 wintermod with new factory air filter. I am throwing in the pictured clutch (Dynamite Max-Life w/ springs) and new air filter. The head has been cut down to allow cold weather running. This engine has ONLY been ran in the COLD after break-in with a total of about 1 galon of use(1/2 break in 1/2 cold running). It comes with no warranty whatsoever. If you did not want to run this in the cold you would simply need a new head. $40 SOLD elsewhere!
http://imgur.com/a/gfmld
Chassis:
FLM Tranny Forward Brushless conversion, NEW never ran, only mocked up. Comes with everything pictured. The motor mount has been modified to fit the Castle 1717 motor, and if you are using a regular sized motor I recommend purchasing a new mount. There is a second mod on this kit, the servo plate by default is only held up by the steering posts (BAD!). The TVP's have been drilled to accept a second support brace. See pictures. $135
http://www.fastlanemachine.net/proddetail.php?prod=FLM49000&cat=29
http://imgur.com/a/ilSMR
Drivetrain:
4 Savage X SS driveshafts, two axle cups, two diff cups, and 2 stock trans-diff driveshafts. Have these laying around left over from the orig truck. $3 gets you all pictured, plus the two axle cups which are missing from the picture.
http://imgur.com/azOey
6 used straight (as far as I can tell), 1 new (5th over), and 1 bent Flux dogbones, 4 axle cups with minimal wear to the cups. $25
http://imgur.com/K7hfQ
4 Proline 24mm Hex Converters. Threads and pin holes are in good shape, see pictures. Will throw in 4 pins as well (not pictured). $10
http://imgur.com/a/P9zEB
Suspension:
HPI Savage Racing Suspension Conversion Kit. This is easily my favorite upgrade for the Savage. In good condition. One of the hinge pins on the factory kit bent (cheaper SS than regular part), so I replaced with a stock hingepin. Can easily set properly with some fuel tubing or washers (ran this way for galons of fuel.. $80
http://imgur.com/EmE6l
Savage Suspension Arms. 4 used (2 of each), 4 new (1 of one, 3 of the other) and 2 uppers. Pictured bottom is used, top new. $10
http://imgur.com/nXrh0
Misc Savage:
PRC Savage Wing mount PRC184, Hot Body C8152 Wing Stay, D8 Wing. Everything here is fairly beat up but, still fully functional. You will find when you put a wing on a savage it will not stay perfect long. The benefits are worth it IMO. The wing is bent, scraped. The wing stay is slightly warped. The PRC mount is good other than a carbon fiber chip at a bottom corner. I recommend sealing with CA glue before use. See pics for more details. $15
http://imgur.com/a/XNS2P
First up, tires:
Electronics:
Engines:
Chassis:
Drivetrain:
Suspension:
Misc Savage:
