Something really went wrong...
Oops, hold on guys. Accidentally pressed post before I added the pictures.
ahhhhhhhhh how did you manage to do that??????????
do you have reverse??? might have caused it...
I told you not to chew on your clutch bells no matter how good they taste!
Not sure on the CB you plan to get for your metal spur but I used a Golden Horizon steel spur and the HPI HD clutch bell and it ate it up with a few tanks.....i would suggest something harder or stay plastic.....
I always liked metal at the time I was messing the plastic ones up but so far with 6 1/2 gallons I have only messed one spur up, and that was because I bent motor plate.
The Robinson racing combo will last you forever as long as you keep the mesh right, RR products are tough.
Yeah, RR stuff is costly.
Big worm, I have FLM stuff, so I really doubt its cracked, but I did have a screw missing, so that may very well be the problem I had also.
