Single Speed Savage Gearbox ?????
Savagesam
Single Speed Gearbox With Pics Mod ????
Hi there guys i have been looking at the idea of how to set up a single speed gearbox for the racing savage's around the world.
I have tested the second gear in a 2 speed box wound right out so the car starts in 2nd and using the 17/47 set up with a modified picco ( purenitro - extreme rc mods ) the truck launches of the line hard and has enough gearing to be peaking in rpm's at the 40 mitre mark which is enough for most straights on off road race tracks.
I then removed the the centre gear shaft in the 2 speed box and removed the 1st gear completly leaving the one way bearing to fill the space on the shaft before fitting the 2nd gear into place.
NOW FOR THE FUN BIT : I then made a custom delrin clutch replacement which replaces the flick clutch that fits into place and secures the 2nd gear into place so as it is fixed into place with a threaded pin screw and grub srew to hold it into place.
So i have tested it and with the lighter gearbox the spur gear and drivetrain spools up faster and when the brakes are applied the c/b shoes and springs close just like a truggy set up, the truck was spinning off the line on concrete which was insane.
HAS ANYONE ELSE TRYED THIS - OR DO YOU HAVE ANY FEED BACK ABOUT THIS AS I HAVE A LITTLE CONCERN ABOUT THE SUDDEN STOPPING OF THE GEARBOX USING THIS METHOD - SO FAR SO GOOD WITH 2 TANKS ON THE SET UP ?????
it does sound really interesting...... i liked the way my 1 speed truggy ran actually..
I know one guy that did something like this too. I believe he just gutted the tranny and only left the 1st gear in there. He was obsessed with keeping his truck super light. Oh yeah, pics please!!
reply
I spoke to bank about this idea before trying it, i was looking to use the gear ratio's of the 2nd gear as they work great for racing and also using the plastic 2nd gear in the gearbox and 47 plastic spur and 17 - 18 c/b there is still some weak points in the driveline too.
With the all metal flux gearbox using the 43 metal spur and 19 - 20 c/b to have the same gear ratio there is no weak point in the drive line, thats why I'm trying to use the set up i have made up for now
sounds col sam....let's see some vids of that thing tearing up a track!!
pics
pic 1 - the three items are the stock flick out clutch, flick out clutch fixed into place ( for testing ), delrin plastic fixed 2nd gear mod
pic 2 - stock 2 speed gear & clutch set up
pic 3 - modified 2nd gear fixed truggy style delrin plastic gear mod installed
pics
Pic 4 - 1st gear removal and take away any access weight keeping the one way bearing for spacing out the shaft
Pic 5 - 2nd gear fix mod installed in the gearbox ready for action
Pic 6 - stock 2 speed gear box ready for action
